ann tanner
20 points
Posted on - 09/07/2012
Hi I am just a newbie in this lotus notes, how to create a calendar using this software and how to categorize the colors for example in holidays and scroll bar colors? Need tips and help. Thanks
Creating calendar in lotus notes calendar with color category
Before downloading any extra user manual for your Lotus Notes from the web, you should check first your program’s Help section or Help menu. It should contain valuable information regarding the different functions and capabilities of the software. I think this should also list some Tips and the Frequently Asked Questions of the program or FAQs. This part of the program will help you learn even the smallest part and function.
But if you really need to have the actual user manual of Lotus Notes, you will find it at IBM – developerWorks — Lotus Notes documentation. There are user manuals that are available in PDF formats so you need to install Adobe Reader first before you can open the file.
