Creating Crazy Genetics Android App for Detecting Gene Identification
What modeling and coding languages can be used to create a crazy genetics app that will detect gene identification and what ideas can be incorporated in this app to further its functionality?
Answered By 0 points N/A #169724
A programming language is a language for your computer. It is also an artificial language. It is based on some codes that help a machine to understand what the user wants.
Modeling and coding are also part of a programming language. A program is based on different, and possibly many, codes. While you are coding a program, be careful at that timebecause any little mistake may create an error.
 I suggest that whenever you are going to make a program or app, focus on the coding steps.
