Creating a Diagram in MS Excel
Good morning everyone, I am currently working on something in MS Excel. I wanted to create a diagram based on the data I imputed.
How will I do this? Anyone care to help me?
To create a diagram on MS Excel:
1. Make sure you already have an idea of what type of diagram you would like to use.
2. Once you already know what diagram to use, you may start creating it in Excel using Smart Art:
Please note that you can’t save the diagram directly so once you remove the grid lines you can take a screen shot and edit this in paint or on any other image manipulation program you would like to save it.
To view the video tutorial in creating a diagram on MS Excel.
The following are the steps to follow when making diagrams using excel. Highlight the data that you want may be a chat to be drawn. Do not include the title column of the data.
Go to insert and select chat. Click on the chat wizard. From the chart wizard you will be able to see the following options:
From the above you may select what you want to insert. If for example you use pie then hold down the mouse to see how the chart would look like. If not satisfied with the current type you still have the option of choosing next. If satisfied choose finish. The chart will have an option to specify the range of the data you want. When you are done you Go to the next step where by you put title to the chart.
Select next to be able to see how the chart would look like.
