Hi everyone, Recently, I have learned about Disk Cloning as another method of Backing up your Data. I need someone’s help in finding the Best Free Disk Cloning Software. Satisfactory and quick help will be appreciable.
For Creating A Disk Backup, The Best Free Disk Cloning Software.
Disk Cloning is a method that is used to copy all the Data from a Disk to another Disk to keep it ready in case of any Data Loss.
AOMEI Disk Cloner is the best Disk Cloning Software in my view. Using this Software, you can Clone data from a Small Disk to a Large Disk and vice versa. You can Clone your data from Disk to SSD as well.
To start the Cloning process, follow the steps.
1) Open AOMEI Disk Cloner.
2) Select the Source Disk whose data you are cloning.
3) Choose the Destination Disk to copy the data.
4) Click on “Start Clone” to start the operation.
