I wanted to ask if with the “Active ISO Manager Freeware” can I create ISO file from DVD – ROM.
I am sure that I can create from a CD-ROM but what about from a DVD-ROM.
I just need to create files from a DVD-ROM with Isa manager freeware.
Creating files with iso manager freeware
Hi Robert Patrick
There is one of the greatest software available for creating ISO files from any source such as CD-ROM, DVD-ROM, FLASH Drive, USB etc, Named Magic ISO.
You want to create ISO file from DVD-ROM.
It is very easy with Magic ISO.
1. Install it in your system and run it.
2. Then Insert DVD in your DVD-ROM and wait to run this.
3. Select all files which you want to put into .ISO file from DVD Panel and Drag it to blank ISO Section.
4. Then Automatic total size will reflect in the size bar.
5. Click on File, then Select Save, Enter file name which you want to give and Click Ok.
Done You have created the. ISO file from DVD-ROM.
Use context menu entry "Extract here" or "Extract here (to new folder)"
Use context menu entry "Extract. To be asked for output path and other options
Open the archive in PeaZip in PeaZip and use "Extract" button (you can choose output path, enter password and other options before confirming with "Ok") to extract selected object, or Extract > Extract all in an application's context menu to extract all the archive
Open the archive in PeaZip and drag desired objects from the application to the system (the opposite can be used to add objects to the archive)
Open the archive in PeaZip and double click on an archived file to open and view its content
