Creating first project in editing software Adobe Premiere CS6
60 points
Posted on - 04/20/2015
I would like to ask what is the use of Adobe Story? What is Adobe OnLocation? What is the use of it in CS6? Can you provide proper way on how to create and open a project in Adobe Premiere CS6? How can I add titles in CS6? What are the common transition effects I can use in this software? What are the additional transition effects added in this software? Can you provide it to me and what are the outcome of using this effects? Where can I emulate audio and change the properties and settings of the audio of video? What does FLV means? What is the difference between Mpeg-4 and Mpeg-2?
Thank you!
