Creating flashing background when opening a web page.
This terms is totally depends on you or on your creativity I can only tell you about a template or I can tell you about the tools or the environment which you can use or some example of this kind of creation. Java script is the vest and most used tool that helps to make this kind of effect and to use java script you need a good environment. I recommended you to use Adobe Dreamweaver which good environments now which code can you use for an example to make this effect. Go to this site to have the code: https://www.computerhope.com/issues/ch000058.htm good bye.
You mean you want to create a flashing background when opening which kind of page. It is a website that you are designing and you need to create a flashy background is it any other application like PowerPoint? You could have at least mentioned which application you are using for there are a whole lot of places where flash backgrounds can be used.
But I will take it that you are designing a website and you need to create a flash background. If that is the case, then you will need to get an application for creating flash images and some of those applications are:
You will just need to get whichever pleases you and install it on your computer, and then use it to create the flash backgrounds for your website. You can get tutorials online to guide you for the applications that may be challenging to use.
-Clair Charles
Notifications
