Creating floating chatbox for a website using html
I have a website. I want to create a floating chatbox in my website. But do not know how to create it. Please help me to create the floating chatbox for my website using html codes.
Hi Steve Randle,
For creating a floating chat box in your website
You have to edit your HTML code of your website.
The website you have there you should write some code which you will get from following link
That link is https://www.codingforums.com/javascript-programming/166463-putting-floating-chat-my-site.html
There are some JavaScript codes you should remain this code you can change CSS code.
Then you will see the floating chat box in your website.
Thanks
