Ryan Abate
30 points
Posted on - 05/01/2013
I want to make a GIF image of a Smartphone that I can use on my blog in Tumbler. I am not really good on editing or creating a GIF image, so I am looking for any software that will do the work. What is the best software for creating GIF images? It should be user-friendly and very reliable. Please include details about the software.
Creating gif Smartphone see for possible applications
Hello Ryan Abate,
If you want to make GIF images then I suggest you to use Photoshop so that you can get the easy way to do that task. All you need to do is to download that software from the below link. It is a best and user friendly software that can help you in making the GIF images easy to make. In that software you can also convert your other images in any format that you want to convert. And also you can add other things in that image.
https://freesoftwaredownload9.blogspot.in/2013/04/adobe-photoshop-cs5-free-download.html
Hi Ryan!
You can actually can create an animated GIF using your Smartphone. All you have to do is download and install Cinemagram apps to your Smartphone then you can start creating your own animated GIF files. Cinemagram is easy to use and it has existing effects that you can add to your work.
If you are using Android version, you can download Cinemagram on Uptodown:
http://cinemagram.en.uptodown.com/android
If you are using the IOS version you can download Cinemagram on Apps Store and in Udtodown:
https://itunes.apple.com/us/app/imgplay-gif-maker/id989843523?mt=8
