Creating HTML 5 gallery with Juicebox 1.0.2
I’ve come to know about the software Juicebox 1.0.2 which is able to create HTML 5 gallery in a flash. Will the desktop version of the software work on Linux and Macs without any problem?
Yes, absolutely. It will definitely work on Linux and Mac OS X operating systems. To give you the full system specifications of the application, Juicebox 1.0.2 supports Windows 2000, Windows XP, Windows Vista 32-bit and 64-bit, Windows 7 32-bit and 64-bit, Windows 8, Mac OS X, and Linux operating systems.
This version works on a wide variety of platforms to reach wide number of users that use different operating systems on their computers.
This program also requires installing Adobe Air. So, before installing Juicebox 1.0.2 on your computer you should install Adobe Air first followed by Juicebox 1.0.2 to avoid any installation problems. I’m not sure if this is the latest version since it was only last updated on May 23, 2012. To download Juicebox 1.0.2,
