When I try to create a new connection with the putty connect manager ext it gives me an error. When I enter the shell login and password, it freezes and stops responding. Is there any way I can fix this? I've tried reinstalling the program with no luck.
Creating a new connection with the putty connect manager ext
Hi Michael W Rayner,
Regarding to your problem in Putty connection manager, I can see 2 possible reasons why this is not working.
1. This is not compatible to your computer system or your system can't handle this kind of program. So you need to download the Putty connection manager that compatible to your system. You can download it at this link https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html.
2. The putty connection manager is illegal to some country because of the encryption is not allowed. You can see if your country is restricted in this site http://www.cryptolaw.org/.
