Hi there,
I have a word document in a Mac book which I intend to convert to a PDF format, I would also wish to create some more PDF documents on the same OS, how do I do this, and how do I modify the documents after the conversion from word?
Creating PDF documents and converting Word docs toPDF in Mac
If you need to convert a word to pdf format in MAC operating system, please follow the following steps:
1. Open the word file.
2. Select Print from File option.
3. Then click PDF in the print dialog box.
4. Select “Save as PDF” from a number of options that will pop up.
5. Name your PDF etc.
6. You can also password protect your PDF if you want.
7. Click Save.
