Creating Powerpoint presentation using iPod
 I want to be able to make Power Point presentations using my iPod. Can you tell me how to go about it?
I don't know what specific Apple device that you have. So if your device is an iPad, there is Keynote. You can recognize Keynote if you have a Mac device. This application is easy to use and is very interactive. For iPhone/i Touch, there is Documents to Go. You must buy a license for Documents to Go for you to have a PowerPoint maker. But somehow, making PowerPoint presentations in Documents to Go is limited. You could only enter slides there, increase or decrease indentations and type as you go.
The application is meant to be somewhat a head start so that later on you can edit your presentation in a computer. Hope it is of help to you.
Hi Jones,
There is a problem about your question ,because you have not denote, which apple iPod you have?.The creation of presentation is deference one by one. However I will give you a guide with keynotes. Use it and understand , how to do it is the question. It's not difficult to do. I have given below some website,which are explaining about your question. Please use them and easily fix your work.
