Creating ppt web log format website
Can any body here give me a link to a ppt web log format created website, and suggest me the ebst way to create the website with the similar ppt web log format desogn. Some links to tutorials as well.Â
Hello Tammy,
·        I am going to tell you one of the best website to learn how to create the website. Click on the below link
·        https://www.w3schools.com/
·        It opens up the website.
·        This website having all the useful information along with the practice questions. It will be very helpful for you. Hops so, It helps you a lot.
Regard,
Harthy Opera
Hi Tammy calloway,
There are many web and cloud-based slide presentation software you could use. I would suggest Prezi, which allows users many display and navigation options for their presentation. You would have to sign up to use the program, but it's easy:
1. Go to the Prezi and choose either paid or unpaid licenses to suit your needs.
2. Key in the required personal information, including a password.
3. Start creating presentations.
Hope this helps.
Murakami Wyatt
