Creating a simple program in VB 2015 with highest and lowest value
20 points
Posted on - 04/09/2015
I want to create a program that can accept 3 numbers. Display it back with options like highest to lowest or vice versa. What are the objects I need to use to make this work? Can you please explain to me step-by-step or line-by-line how the program will work? Can you show me how to create .exe file out of this program. What are the possible or problems you encountered while doing this small program? Thank you very much and have a nice day!
