Creating stylish glitter Photoscape shadow in a picture
Dear Techyv Friends,
Does anyone has previously used Photoscape [a free photo editing software], If so please help me. I would like to know about how to create stylish glitter Photoscape shadow in a picture. Please do the needful for helping me by explaining the process.
Thanks & Regards,
Jair Zachery
Best Answer by Alexander Dubson
Answered By 5 points N/A #199289
If you want to know how to add a glittery effect on Photoscape, you can watch on the video below. It consists of step-by-step instructions that you can follow.
[video:http//www.youtube.com/watch?v=H2r75QABoPg autoplay:0]
Answered By 0 points N/A #199290
Creating a glitter shadow with Photoscape is something that is not that far-fetched and with some practicing, the effect can always be bettered.
Here is the basic process behind it:
  1. After opening the .png file you should go to ‘Bright, Color’ and change the ‘Contrast’ to -100.
  2. Put on a Noise filter at 255.
  3. On the arrow of ‘Bright, Color’, use ‘Colorize’ and choose the color which you want to use on the created shadow.
  4. On the ‘Object’ tab, click ‘Photo’ and pick the original file and place it next to the effect created.
And here you have created a glitter shadow. You can use any further effects at your choice on the final photo.
