Creating a Template on MS Word
Good evening.
I've been assigned by my boss to create a template on MS Word.
The problem is that I don't know much about it but I just cant tell my boss about it.
Could somebody tell me what template is?
What are the steps to create a template?
Answered By 0 points N/A #100325
You can think of a template as a model. A template is usually created to avoid difficulties in following formats or creating a new one. When there is a template, all you have to do is follow its format and focus on the content of the document. Some examples of documents that commonly have templates are certificates, letters, and resumes.
Here is an example of a template for a certificate:
Image was taken from the link given below (feel free to browse through all the templates available in this website)
You can download the template that best fits what you need from https://templates.office.com/?legRedir=true&CTT=97&CorrelationId=f7e7a724-cb80-4854-a91d-b9669c0d5baf.
If you can’t find one that is similar to what you need you can always create a new one.
Good luck!
