I am currently using Google chrome as my default web browser. Google Chrome have this theme function which, ideally, you can change your browser theme into your liking.
Can I import a theme from Google chrome and use it as the theme in my VB application? By The way, there are times that when I watch videos in YouTube, it does not buffer? Is this a bug?
Mark H.
Creating Themes for Google Chrome?
There Jennifer! In some instances, using Google chrome in watching videos on YouTube, it really doesn't buffer. I encountered that many times. I also have figured out on how to fix it.
Just clear your cache into no avail. Clear all your cookies and buffering will go back to normal. And about your other question, yes you can import a theme from Google chrome and use it as theme on your VB application.
Just import GIF image by simple image and don't import GIP image using images with background. I hope it helps. I'll be glad if these solutions will help you solve your issue.
Mark
Hi Jennifer Belle,
I suspect that your question has an answer but no. Because Google chrome A theme which is a special kind of extension. which is installed into the browsers native system. So in order to use these themes as VB applications you must need to convert those APIs and integrate with visual basic.
I suspect that you must be finding a way through which you can integrate Google chrome with visual basic instead of integrating Google's themes with visual basic. However, you can integrate Google chrome with visual basic application.
lee hung
75 points
Hi Jennifer,
I strongly think that you can use the themes from Google chrome to your visual basic application. You can just download the theme which should come as an image which you will then save in your folder of choice say in my documents or may be on the desktop.
From there you can import the video to your visual basic application. Before you use in VB, you can edit and customize the size, color and other options like the contrast of the image so that it fits well in VB.
As for the videos you are watching on YouTube not buffering when you are using Google chrome, I do not think it is a virus but instead you are having very fast internet connection and also Google chrome is one of the fastest browsers. So do not be scared.
__
Lee Hung
