Creative Suite 5.5 Design Standard attempted to install this got error message
Recently, I downloaded Creative Suite 5.5 Design Standard and I attempted to install this software I got an error message at the end of the installation.
I have reinstalled the software and restarted my system but I could not solve this problem.
How can I fix it easily?
I really need your assistance.
Thanks for help.
Installation Status Your installation encountered errors. Please try restarting your system and installing again. Exit code: 7
Installation Status
Exit code: 7
……………………… Summary…………………………………………………….
. 0 fatal error(s), 73 error(s), 70 warning(s)
WARNING: DW024: The payload: Adobe Photoshop CS5.1 Core {08EF22BC-43B2-4B4E-BA12-52B18F418F38} requires a UI parent with following specification:
Contact Customer Support for Further assistance.
Best Answer by Wright Birkholz
Answered By 15 points N/A #176501
Hi Darrell,
The error is because none of the components were successfully installed.
To resolve this error follow the steps as stated below:
1) Check that the disc drive can read the disc
2) Creative suite installation requires administrative privileges to install
3) Go to 'Start', Click 'Control Panel', Select 'User Account Privileges'
User-Account-window-for-administrative-privileges
4) Check the user has admin privileges for installation
5) Run the Creative 5.5 suite installer
6) Perform a safe boot before installing
7) After the installation is complete, restart the system
Answered By 5 points N/A #176502
1. On your Control Panel, uninstall Adobe Creative Suite 5.5 Design Standard if after you reinstalled, some CS5.5 data are still present.
2. Download and launch Adobe Suite Cleaner tool to fix the registry settings of your local machine.
3. Install the most up to date version of Adobe air.
4. Install the latest Adobe Flash Player
5. On the control panel, uninstall Adobe Reader. This is because it will be replaced with the Acrobat Pro (comes with the Creative Suite by default) which may create conflict if you wont uninstall the Reader.
6. Restart your machine
7. Re-install by clicking Run as admin.
8. This should be working then
