Cricket 2007 ea sports cricket
When I am open the game its asking to browse the folder but when I browse it doesn't open
Thank you very much
Thank you very much
Try to remove the game completely and then reinstall it back. Remove every components of the game so when you reinstall, the folders will be replaced with a new one.
From where did you download the game? Maybe the game you have installed is damaged or corrupted. Try to download again from other website and then install it again to your computer. You can find more information about the game from the link below:
https://worldfreeit.blogspot.com/2016/01/cricket-2007-free-download.html
The game Cricket 07 is a computer simulation of the cricket game from EA Sports designed by HB Studios. The game is available in PlayStation 2 and Microsoft Windows. It was released in November 14, 2006 in Australia and in November 24, 2006 in the United Kingdom. The game cover features Lancashire and England cricketer Andrew Flintoff.
You can also download patches that will convert Cricket 07 into Cricket 08, Cricket 09, Cricket 10, Cricket IPL 5, Cricket 11, Cricket 2012, and Cricket 2013. In your case, it was unfortunate that you did not mention anything about your operating system. Remember, to make the program or the game work you must be running one of the following operating systems: Windows XP, Windows Vista, Windows 7, and Windows 8.
If you are running it on a different operating system like Linux or Mac OS X, then it wouldn’t be possible to play it. If you are running a supported operating system such as the ones mentioned above and you still can’t play it, try to uninstall it and then install it back. Click Start, Control Panel, and then Add or Remove Programs.
Find and select Cricket 07 and click Remove or Uninstall to remove it. After that, restart your computer. After booting, open Windows Explorer and go to “C:Program Files”, find and delete the Cricket 07 installation folder. There are programs that don’t completely delete the folder after uninstalling it. Once deleted, empty your Recycle Bin and install Cricket 07 again.
You may also download a fresh copy of the Cricket 07 installer from EA Sports Cricket.
