As shown in the image below, the CDex- Application was unsuccessful initializing correctly (0 × c0150002). Will I just hit Ok button to stop the application.
CDex- Application failed to initialize properly (0×c0150002). Click on OK to terminate the application.
Why this error happened? Find time to explain this immediately please.
Critical problem in the CDex 1.70 beta3
Greetings,
It's unfortunate your ran into this problem. Fortunately, there are a couple of things we can try. First, I suggest uninstall and re-installing the problem application. So uninstall the program but before re-installing, download and install Windows Installer 4.5 Redistributable. Afterwards, re-install the problem CDex. If problem persists, install .NET Framework 4 from here.
Hello Tony,
There is one other solution to this problem that you may try. Follow these steps –
Download Windows Installer Cleanup utility from here and install it.
Launch Windows Install cleanup, a list of software installed on your computer will appear.
Select the program causing error and click ‘Remove’.
Now re-launch the setup of the program that caused the error and follow the prompts till process completes.
Hope you find this useful.
