CRM, report deletion impossible. How to delete the file?
I was going to delete a report that I have emailed, CRM won't let me delete it, this error shows up.
How can I delete it?
Microsoft Dynamic CRM – Webpage Dialog
Reporting Error
An error occurred while deleting items from the report server.
Nevi
Answered By 10 points N/A #175448
It looks like you are facing this problem as the report has lost its reference. If you have made any changes in the settings of reports, change them back. Make sure you change the settings back to the default settings. The possible solutions for your problem could be the following:
1. Check the registry for any errors. You can download the registry editor and use it to check for any errors in the registry.
2. Check the compatibility on your system. If your system does not support it then you will not be able to delete it.
3. Check if the report has been deleted already from your computer or not. This could be the problem sometimes.
Hope this information helps you.
