Cropping and editing mp3 files
There’s a lot of software available in the market to crop and edit mp3. If you are a newbie in editing and cropping you can try to download Audacity which is a good and simple program for editing. You can download also Audio Mp3 Editor for the beginners who want to try batch converting and streaming. But if you really want more complicated editing you can use mixcraft which is a great and powerful multi-track editing and recording.
If you've ever wanted a fast and easy way to cropping a song in mp3 format. Mp3 Direct cut is exactly what you need. In this post i want to introduce you to the software and we'll go over some of feature and usage Mp3 direct cut feature.
Or you can check out the features on the official website at free software of mp3 Directcut.
The best software available on the internet for editing and cropping mp3 files is Audacity. It is freeware. You can use it absolutely for free. It is also very simple to use as it has a user interface with all the functions available in the working area. It also has a small download size (20 mb with installer or 8 mb without installer).
The download link is https://sourceforge.net/projects/audacity/
There are other software available like Adobe Audition, this however is not free. Others include Wavosaur and Kristal Audio Engine.
There are some pretty software that enables editing audio and MP3 files. “Audacity” is one of them but recommended. It works for many formatted files. You can perform cut, copy, paste and some other operations such as controlling music properties. Search on Google “Audacity” and will get yours copy. Another one is “Diet MP3” is also good.
Have a good luck.
