Laura Annita 10 points N/APosted on - 11/16/2012
Hi, i have problems with this game , so i really need Crysis 2 complete game save files, just to try to load some saved games. If someone has some better way to keep on playing, please tell me. It won't load my saved game…
Hi Laura, the best thing you can do is to copy your saved games from where it's located on the hard drive to another location (take note of the path whence you copied them). Then uninstall the game and re-install it again. After it has been installed. Copy back your saved games into the folder whence you copied them in the first place (make sure the path is the same as it was before uninstallation). You should be able to load saved games now.
Once the file is downloaded, unpack the ZIP file with WinZip or WinRAR or use 7-Zip. Once the file is unpacked, you will have two files with CSF and meta extensions. Copy both files to the save folder:
Windows XP – C:\Documents and Settings\[username]\Saved Games\Crysis2\SaveGames\
Windows Vista and Windows 7 – C:\Users\[username]\Saved Games\Crysis2\SaveGames\
Overwrite any existing files. Finally, start Crysis 2 then go to “RESUME GAME”. See if this works. For more save game files for this game, go to Crysis 2 Save Games.
1....
