Crysis Warhead – Error reading from file
Dear friends,
For the last few days I am getting the following error message.
As I am a new user, I can’t make out what to do. Here goes the screenshot of the error message.
Error
Error reading from file E:dataGame80845C2AC488A571Objects.pak. Verify that the file exists and that you can access it.
Please help me.
Answered By 0 points N/A #131398
Wassup Greg, I believe I will be able to help you with your query. What you need to do to solve this query is to ensure that you use an original downloader for the game, you also need to ensure that the cd or dvd you used to install the game doesn’t have any scratches because that may also be the cause of the error.
Try uninstalling the game software ensuring you delete all the files under the registry editor.
Go to the temp folders also under; C:->Program Files->Crysis Warhead->*86 Delete all the files under this folder.
Restart your computer.
You can then install a newer instance of the game or a fresh instance and it will be working properly.
I hope this solves your query
Thanks
