Crystal report real world, to what extent is our advantage?
To what extent is the crystal report at our advantage in regards to helping us document and summarize business' data reports?
Reporting is a big advantage in any kind of day to day business. Imagine you start a new business and you have small amount of data so you don’t need reporting. But when the amount of data gets larger and larger you’ll definitely going to need a reporting solution. There are many reporting solutions available most of them are commercial products.
Crystal reports are also a commercial product. Personally I use crystal reports for my reporting needs because I have found it more flexible. You can pass parameterize queries, Integrate with .NET base applications, More visualize charting effects. Those are some of the characteristics of crystal reports.  So it’s a not a bad idea at all to use crystal reports as your reporting solution.
