Crystal reports formula biweekly how to’s
I am starting to learn Crystal and I want to know here is already an expert on it. I want to make crystal reports formula biweekly based on the current day and month. Has anyone tried doing this before? Please share the code so i can compare it with  mine…
Answered By 5 points N/A #163742
You can use grouping in Crystal reports. See below explanation.
Open crystal report -> right click Group Name Fields -> Insert Group
You will see the below screen and select group by date field in your dataset.
Report will provide you several grouping options and you can select “for each week” option.
Drag and drop group into your report and the data will be grouped according to the week.
