CS Error message on loading Morrowind_ob.esm
When I load the morrowind_ob.esmin the construction place I receive this error message.
Warning
Second ReadFile () in GetChunkData failed with error:
The operation completed successfully.
Continue Playing?
"Yes to all" will disable all Warnings this session.
I am running v44 of the .Esm, however this has happened since at least v39.
I have performed these things
Uninstalled and installed the CS again
Uninstalled and installed Oblivion, Shivering Isles, patches again etc.
Uninstalled, but again and installed morrowblivion one more time
Unpacked the .esm installer using both 7zip and as well as Winrar
Run the installer as admin Run the installer as user
Confirmed a bit
…and it is coming up again. Any idea?
