CS3 Photoshop Real Serial Number Problem
I downloaded Photoshop CS3 in my pc and fill in the serial numbers so that the application would run without expiration but when I clicked on the icon of the app, it did not run and did not respond from the task given.
Can anyone tell me what happened and how can I solve this software issue?
Adobe Photoshop CS4 Extended: Incorrect Serial Number
The serial number you entered is not valid. Click OK to retry entering the serial number.
Answered By 590495 points N/A #84560
The serial number that you entered in Adobe Photoshop CS3 is not valid for this version of Adobe Photoshop.
There are certain sets of serial numbers that are only valid for a certain version of Adobe Photoshop and here the serial number that you used in registering Adobe Photoshop CS3 belongs to another version which is not clear if it is the older or the newer version.
If you are using a trial version of Adobe Photoshop CS3 and its trial period is still not expired remove the serial number from the program so you can still use it again.
Obtain a valid serial number for this version of Adobe Photoshop. If the serial number that you used was just downloaded from a certain website then just try searching the internet again you might find the right version for the program. Do not try to enter manipulated serials as they always contains Trojans and viruses.
Purchase the software from Adobe website and enjoy the unlimited features of it.
