Hi experts,
During the shutting down my PC this error message appears and I have to click OK every time to continue turning off. Is annoying because I have to stay to my PC until is off and I want to get rid of this error. Please can anyone help me fixing this error? If is possible please tell how can this error be prevented in the future.
Thanks experts!
Csc.exe – Application Error
The application failed to initialize properly (0xx0000142). Click OK to terminate the application.
OK
Csc.exe – Application Error The application failed to initialize properly
You are getting this error because maybe the application is no longer stable. If you always get this every time you shut down your computer but the error doesn’t appear during startup that means it is started automatically in the Windows Startup which happens when you boot your computer. You can fix this by reinstalling or completely removing the affected application if you no longer use it.
The first thing to do is to search for the program. Click Start, Search, and then search your computer for the file “csc.exe”. See image.
When you found it, go to the folder where the file is located which is usually in “C:Program Files”. Take note of the application’s name usually indicated in the folder’s label. Click Start, Control Panel, then Add or Remove Programs. Find and select the application then click Remove to uninstall it. Restart your computer when it is finished and then install it back.
See if this works. It will also help if you install the latest version which you can do by visiting the application’s official website and downloading the latest version.
