Emma Marie
10 points
Posted on - 02/09/2013
Hi Techyv Friends,
I am having the latest version of Cygwin DLL that is 1.7.17-1 on my Windows XP. Will I be able to perform csv to xml conversion Cygwin using any tools. Please suggest me any such tool and let me know, where to get such tool.
Thanks & Regards,
Emma Marie
CSV to XML conversion Cygwin
There is a stable release of a free tool made for Windows that you can use in order to convert XML into CSV. If you do not want to download and install it on your PC, the maker or the product has also made available an online version of it, which you can use online to have CSV outputs extracted from XML files uploaded to it. The online version also allows conversion in the reverse order. A picture is attached for you.
Hope it helps.
Best Regards,
Parisi
