CTT200 access to skype is rejected
The CIT200 is not connecting to the Skype so I just installed the new driver after the uninstall the old one. Now every time I start my computer I receive this weird error message saying “Access to SKYPE is rejected, please try again”. Have any idea to fix this problem? Thanks for any help.
CTT200
Access to SKYPE is rejected, please try again.
Answered By 5 points N/A #185352
Hey Mr.Rodgers,
First of all, to prevent future conflicts it is recommended that you prevent Windows from automatically starting SKYPE.
To do this, open Skype, select Tools>Options>Advanced and then uncheck the box to 'start Skype when you start your computer'.
To resolve the issue you have, go to Tools -> Options -> Privacy -> Click on 'Manage other programs' access to Skype' .-> Select CIT 200.Exe and click on the 'change' button alongside.
In the window that appears, click Allow this program to use Skype, then click OK.
Now, try re-starting your computer and open Skype manually.
