Curious to Know about Sony Xperia P
I heard about the release of Sony Xperia P.
I heard that there is no microSD slot available in this device. How much internal memory does it have?
And I also want to know about its multi-touch support.
Hi Bayonjoset!
Yes you are right Sony Xperia P has no microSD slot but you can use USB on the go to connect USB Card reader for your files.
Here are the phone specifications:
1. It has LED-backlit LCD capacitive touchscreen.
2. Scratch-resistant.
3. Internal 16 GB memory, 1GB Ram
4. Wifi Ready
5.8 MP Camera with autofocus and LED flash
6. Android OS v2.3
7. Dual Core 1 GHz
8. Accelerometer, gyro-sensor, compass
9. SMS, MMS, Email, IM capable
10. Standard Li-On battery.
That's it! Make sure that before buying a Sony Xperia P, check out its features and decide if it suits your taste!Â
Thank you for reading!
Hello there Bayonjoset,
You have heard it right, Sony Xperia P does not have any card slot. Its internal memory is 16GB (13 Gb of which is available for the user), it has got 1 GB RAM. Its capacitive touch screen has a Multi touch support of up to 4 fingers using capability with 16M colors and 540×960 pixels 275ppi pixel density and scratch – resistant glass and an awesome SONY Mobile Bravia Engine and its Dual Core 1 GHz Cortez-A9 will gift a very comfortable and awesome using capability.
Hope you have got the answer of your question. For any tech question, do not forget to ask help from www.techyv.com
Hope you have a great time.Â
Xperia is a smart phone of Sony released in 2008 but it’s quality is being developed day by day.
There are many quality /model of xperia handset such as X1,X2,,,,,,,X10, Xperia X10 mini, Xperia ray, e.t.c. The model X10 released in 2010 it contains WiFi, Bluetooth, 320Mb internal memory, micro SD up to 32 GB, 512 MB Ram, 1 GB Rom, 8 megapixel camera.
The others model contains the same including some difference.
