ji4894we93z
Posted on - 12/24/2011
I have downloaded a good cursor from CursorFX.
It was working properly. But recently it is just disappeared and it shows the Windows default mouse pointer. It is only showing ‘Create Short Cut’ in the Control Panel > Programs section, so I am not able to uninstall and re-install the same.
When I am trying to open the CursorFX it shows me an error message. ‘It is not having an application associated with this as it is not able to perform the action. Kindly, install the application of if it is already installed please associate in Control Panel.’ I don’t know how to do it. Please help me to remove the application or guide me to create an association.
Thanks in advance.
CursorFX error message “associated error”
I have a better solution for you. You will be needing to follow this instruction. At first click the "start" and click the"run".If your mouse is Universal Serial Bus,i mean USB,please type on the bar-sysdm.cpl.Don't create quotation,and click OK.You will be needing to select Hardware tab and click the Device Manager.Please Right click on your active mouse and Properties.
Go to the general tab and double click Troubleshoot.It will help you fix this issue.If the issue is not solved then please install the Microsoft Fix-It USB tools then repair your mouse.
I think you will be able to recover your problem.
Hi friend
I had this problem before. you need to follow then; your mouse pointer have missed it full data to perform. you can re install the windows fix from your Windows disk or exist file. if you are not found it, you will repair it from my instruction.
First you go to Start menu>> All programs>>Accessories and Run option then click the mouse right button and go properties menu. Write down the fix or temp to repair. and select there.
Another one you go to the C drive and windows all programs and mouse option
You may solve your problem after instruction on your PC.
