gsirit
Posted on - 01/10/2012
I made a simple slideshow presentation using my Archos 7 Home Tablet.
However, whenever I move on to the next slide, I had to swipe the screen rather than press a simple button. I find it inconvenient.
The same is true when I made a PowerPoint macro enabled slideshow presentation.
Again, I had to swipe rather than press a button.
I need your help on how to customize slideshow buttons for easier access to my slides.
Thank you very much.
Customize slideshow buttons Archos 7 Home Tablet
There is no way you can re program a button in a tablet to work as you want it.
The reason behind this is that these all functions are defined by the operating system these devices are carrying with them. In order for them to understand or to do what you want, is to make an OS of your own and install it onto the device so that it performs the thing you want. Sometimes the developers allow such options for the convenience of users but this is more of a fuss than a portable feature. You have to use your finger to swipe through slides.
Also I want to point out that macros have nothing to do when you put them in the tablet. Tablet OS is not capable of recognizing macros patterns so don't waste your time in programming macros to perform this function.
