Customized version of Firefox 12
Pale Moon x64 12.1 is a customized version of new Firefox 12, speed optimized and 64 bit. How to strip out components e.g. parental controls and the accessibility features using this program?
If you would like to remove the parental controls as well as the accessibility features, you need to download the Pale Moon 12.2 Portable instead. Pale moon x64 12.2 already disabled the following components: Accessibility Features, Parental Controls, Maintenance Service and miscellaneous things like Crash Reporter. This version already disabled the features listed by design. The features you will have in this customized version are: optimized for current processors; fewer crashes; has support for Scalable Vector Graphics (SVG) and Canvas; supports Firefox Extensions (add-ons) and Themes; supports Personas; supports CSS Downloadable Fonts; HTML5, CSS3 and advanced DOM support; you will also get the reliability and stability of Firefox browser code, its options and features; increased speed for scripting and page rendering; uses less memory because of the disabled features.
