Customizing Movix to select an AVI
When using my Movix, I tried selecting an AVI which would best work for me but it's not allowing me to do so? Can I customize my Movix so it can load a an AVI of my choice?
I’m not really sure what seems to be the problem with your application because AVI files are pretty much supported by MoviX. If you are already using MoviX before and this is the first time you encounter this type of problem when loading this file type, try restarting your computer then try again. If the next attempt didn’t do any good, try uninstalling MoviX from your machine then check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton SystemWorks.
After checking your system, install MoviX again. This will fix any corrupted files in the installation and will restore the settings back to default. If you still can not play any AVI files, try converting it to another format. MoviX supports these video file types:
