Customizing a shopping cart software freeware using JavaScript
How do I customize a shopping cart software freeware on my eCommerce website using JavaScript as the scripting language and what is the best development environment to facilitate the customization?
Best Answer by Devid James
Answered By 0 points N/A #165460
Hi Thor Peiann,
If you wish to add a shopping cart system on your website easily then I think JavaScript in PHP is very easy & best.
It depends on what you want in shopping cart items? Like product Name, ID, Unit Price, Picture & Customers' Name, ID, email or account verifications etc.
Or you can just use calculating system on your website.
So if you want this then check out my attachments for different solutions.
Answered By 0 points N/A #165461
Dear Thor peiann,
Hope you are well and still waiting for my suggestion. It is possible to customize a shopping cart software freeware on your eCommerce website. You can do this using JavaScript as the scripting language.  The web programming language PHP might be very suitable for this issue. But depending on the application it might be comparatively hard. Hope you enjoyed my solution. Keep enjoying!
Shopping cart software freeware
Best wishes-
Devid James
