Hello Friends,
I am using Windows 7, I would like to customize the mouse pointer with one of my png file. Please advice me about changing Windows 7 pointer png with the png file I would like to have it as pointer.
Please Help me with a solution, Thanks in Advance,Â
Coshaun James
Customizing Windows 7 pointer png
Hello Coshaun
This is a very easy-to-do thing, customizing your Windows pointer. I assume that you have in your PC the PNG file that you want to use as pointer.
So you must go to Control Panel -> Appearance and Personalization -> Personalization (The same as Right-Click on your desktop -> Personalize)
In the left, click on Change Mouse Pointers. And from there, in order for you to select a specific pointer from your computer, press the Browse button and locate the PNG file that you want to use. Click on, and your pointer is now customized.
I hope this will help you solve your problem.
Randolph
