Cute icon signal formation for a game
I am going to make a game and want to add some cute icons as signals and indications. Which software is useful for cute icon signal formation in a game?
There are many softwares available that are used to create an icon. Most of them are free softwares but there are also softwares that are priced. The free softwares do not have advanced features. If you want just the basic features then the free softwares will be good for you. You just have to keep in mind that you should not add copyrighted images as the icon. Just use images from the game to create an icon. Also make a note of the standard sizes to create an icon. The following softwares are the most commonly used softwares to create icons:
1. Axialis – You can get it here – https://www.axialis.com/. See the screenshot below:
2. Icon maker – You can get it here – http://www.icon-maker.com/. See the screenshot below:
If you are looking for icons to be used on your game or possibly on some other purposes, you can try some of the following free vector web icons.
Dashboard Icon Set – best used when you want to build a dashboard for your settings page. Go to Dashboard Icons to download.
Free E-commerce Icons – best used on online stores as shopping and cart elements to have a good looking interface to get sales. Download Free E-commerce Icons for free and use it in any project you may like.
Flat Free Web Icons – click Flat Free Web Icons to download.
Wi-Fi Signal Icons – go to Wi-Fi Signal Icons Page to download.
Round Transparent Social Media Icons (PSD) – they are 100 percent vector-shaped social media icons. Go to Round Transparent Social Media Icons to download.
