Cutting Off The Problems With Windows Dot NET Framework 4.5
I am facing an issue with uninstalling Windows .NET Framework in windows 8. Answering this would be of great help.
Hello, windows .NET Framework 4.5 is used for better performance, reliability as well as security.
a. Firstly, we should not uninstall the .NET Framework because some applications in the system depend on it.
b. If you are facing any issues, then you can get the latest version of .NET Framework from download setup and then rerun it.
c. If you are receiving an error, then make sure you uninstalled the older version. You really can’t uninstall a version you can only uninstall its preview.
d. If you are uninstalling because of the setup not working properly as windows update service is not available, then check maybe the system might be configured to use windows server update services instead of Microsoft windows update. Please let us know how this works for you.
Notifications
