Cyberlink Power DVD 7 Changing My Themes
Hi
I’m using windows 7. I have Intel core 2 duo processor. My motherboard is foxcoon and ram 2GB DDR2. I also have a graphic card. My graphic card model is Nvidia 9500 GT. When I use cyber link power dvd 7 and try to play dvd files,  the aero theme of my windows became the basic themes. I don’t know why this happening. I’ve all configuration it needed.
Please help me how can i fix this problem. I’ve also included two photos for best understanding.
Best Answer by Sharath Reddy
Answered By 0 points N/A #106908
Dear khilna,
i think your cyber link power DVD has some problems. I think you should uninstall it and then install a new cyber link power DVD. This will help. If you can not find a new one then you can reinstall the previous one .
Thank you for your question.
Answered By 590495 points N/A #106909
Your problem is another example of installing a software in an incompatible operating system. CyberLink PowerDVD 7 is not meant for Windows 7. You can install CyberLink PowerDVD 7 on a computer that is running on Windows 2000, Windows Millennium, or Windows XP platform. You are using Windows 7 on your computer and the newest version which this application can be installed is Windows XP. You may try upgrading CyberLink PowerDVD 7 to CyberLink PowerDVD 12 which is available at https://www.cyberlink.com/downloads/trials/index_en_US.html.
It has a free trial version. Or, if you don’t want to upgrade your version of PowerDVD you need to replace your current operating system to Windows XP.
