I received the error Cyber link Power DVD is not optimized for this screen resolution, so I went ahead and downloaded Power DVD 12. Same error appeared on version 12 so I reinstalled version 9 because of system requirements. Can anyone help me please to fix this error ?
Thanks !
CyberLink PowerDVD 9 is not optimized for this screen resolution and will now close.
OK
de Blair
10 points
Cyberlink power dvd 9 screen resolution error
I am presuming that, either,
You are using more than one monitor at your work station, or
Your monitor's display, view may be set to "portrait".
This is very old issue which is associated with Cyberlink PowerDVD software. Unfortunately, despite of launching 5 major upgrades, the developers of Cyberlink still unable to resolve this issue. I am afraid to say in this case you left with only a few options:
Disable rest of the monitors, but one while using Cyberlink PawerDVD player.
Try playing after changing it to "landscape view".
Using any other players like CinePlayer.
Hope these solutions help you to resolve your problem.
