CyberPatrol Setup – Server Error
CyberPatrol installation has failed to throw an error message.
The screenshot of the error message is as under. It is indicating that the product is more than 15 months old.
Recently I purchased it from the Amazon.
Have you any idea for the issue?
Please help.
Thanks in advance.
CyberPatrol Setup - Server Error
ERROR: This product is more than 15 months old and cannot be installed, please obtain an updated copy.
Best Answer by Linknya Jean
Answered By 0 points N/A #192894
Hello Jhon Anderson,
Thanks for sharing your problem with us, to successfully install CyberPatrol on your computer please follow the following steps:
1. First of all download the 7.7 installer from the following link.
http://downloads.contentwatch.com/cyberpatrol/CyberPatrol77.exe
2. Close all the open application and disable all the anti-virus and firewall program.
3. Double click on the file which you have downloaded earlier in step 1.
4. And just follow the onscreen instruction to install the program.
I hope this will help you.
Answered By 0 points N/A #192895
I personally prefer a nice little app called Qustodio. It's Its free, light weight and easy to use. There are a few cool features too like the extensive reporting feature that let's you view the data for the past 30 days. You can also watch the profile pictures of accounts on Facebook. You can download it here www.qustodio.com
