‘Cyclic redundancy check.’ Error message
When I load software or a game on computer, the error message appears: ‘Cyclic redundancy check.’ What does it mean?
Best Answer by Sharath Reddy
Answered By 55 points N/A #90418
This CRC error usually referred in hard disk and external devices for storage. It helps to check the data that is being stored in them. When it’s faulty you get the CRC error.
  • This error points to the fact that the data that you are trying to copy is either in unknown format or is being damaged somehow.
  • It may also occur if you try to transfer a huge number of files at one time.
To solve this problem, follow the steps I am mentioning below. It will surely help you out.
  • First check if the cable that you are using is damaged or not. If you have a spare then try to replace it and then do the copy thing.
  • You can also use Jfile software from here. It is one of the few software specifically designed to repair CRC errors.
  • You can also try Seagate SEA tool for getting rid of this error. The download link is here. There is the least possibility that there is something wrong with your external hard disk but after doing all of these and still you are having the issue then contact the person from which you bought it.
Answered By 590495 points N/A #90419
In layman’s term, it simply means the application or game is already corrupted. The problem has to do with the status of the file or files. This may be caused by one or several of the files getting damaged or corrupted. If this error happens when you are about to load your game on your computer, it is possible that one or more of your game’s files is or are corrupted. This can usually be fixed by simply reinstalling the program which literally replaces all the files in its folder with the default ones. If you still have your game’s installer or your software’s setup file, simply reinstall them.
Uninstall first the affected application and then restart your system if necessary. After that, run the installer again to install the program. But if you still receive a CRC error even after reinstalling it, the problem may now be caused by your hard drive and it seems at this point, there is a portion in your hard disk that has bad spots or bad sectors which needs attention. You can fix it by running a disk utility on your computer and automatically marking these spots so it can’t be used again.
Answered By 40 points N/A #90420
Unbelievable! Michelle Bang and Sharath Reddy, I heartily accepted all of your comments as well thanks. I am a game lover, so you realized when I saw this error message, I was at a loss, I did not understand what to do, also I got panicked. I have tried to solve this problem myself as well I have moved heaven and earth many websites on the internet for a reliable solution but their solution was hazy, I could not apply. But both of your comments were helpful, but Sharath your comment conquered my mind. You gave an exact detail on how to solve the issue. How nicely, you have indicated my problem, as well as according to your advice, uninstalling corrupted files then restarting my system, I saw with surprise that my problem has disappeared. I am very happy now, thanks Sharath Reddy for giving me your helping hand.
