Jay H Tyson
Posted on - 08/14/2014
I haven’t used Cydia in a while, but when I started running it today, I get this error message when trying to install new apps. Last time it worked just fine and I never had an error. Can anyone help me please to fix this error ?
Thank you experts !
Error
Command ‘dpkg-I cydia.deb’ Failed with return code 1 and error message dpkg-deb: ‘cydia.deb’ (…install):
Subprocess dpkg-deb –control returned error exit status 2
Error were encountered while processing:
Cydia.deb
Cydia fails executing command and return code
You did not mention about your device. Follow the way to solve the problem:
1. Your device is connected to internet with valid IP address
2. SSH into your iDevice.
· You need a jailbroken iDevice.
· Open Cydia > "Search"
· Write "OpenSSH" in the search field > result!
· Install "OpenSSH" on your jailbroken device.
· Download WinSCP.
· Install and run WinSCP. [Make sure you have an active Wifi connection on your computer and iDevice.]
· Input your iPhone's IP address [under "Host Name:" field in WinSCP.]
· Root > User name
· Alpine > Password
· Press "Login" button
· Press terminal button / "CTRL+T"
Click ‘Terminal’ icon in the WinSCP's toolbar to launch the Terminal.
Enter root password: [Enter "alpine" and hit the enter key.]
ssh root@(iPhones IP Address)
· Remove the current installation of Cydia.
apt-get remove cydia
· Reinstall Cydia.
apt-get install cydia
