D- Link Adapter DGE driver
Hello and thank you for your answer. I bought a brand network card D-Link (AdapterDGE-528T GIGABIT PCI), but my problem is that my CD player stopped working and I cannot install the driver with the cd.
The seller told me he had to download the driver from the site-link.
But I cannot find on this site can download the driver.
Can you enlighten me?
Thank you.
Best Answer by michel.02
Answered By 0 points N/A #79640
Hello there, You can download and install the driver for the lan card from this website
Download Link
Go to this location and download the appropriate driver for your Operating system.
Michel
Answered By 0 points N/A #79641
I think you need to type in the search page like this "D-Link LAN Card driver for [Operating System]" This is the most appropriate way to look for it. If you bought it as a new then I'm sure it is easy to find.
You can also replace you CD player or just borrow from someone. Also try cleaning your CD ROM or check all of its connection, it might be easy to fix and then try installing the driver using the CD so that you won't have any hard time installing your driver.
You can also try placing the CD on other computer and then copy its content to a USB, then run it on your computer and install the driver using it. This is much easy than searching for the driver that gives you a hard time on looking.
