Is there an app for the iPhone that can control both D-Link D-View and Axis IP cameras on a single server? I have a 64 GB iPhone 5 with Apple A6 chipset and iOS 6.1. Any feedback for d view cam axis app for iPhone? Thanks.
D view cam axis app for iPhone
Hi Debra Carter,
I don't think so that the application you were asking for your iPhone has not yet created.The only application you can use to your iPhone is just the D-link because it just the one that is capable for your 64 GB iPhone 5 with Apple A6 chipset and iOs 6.1.Dont try any application for your iPhone that is not compatible because it can cause such a virus or any errors.Make sure before you use the application you were using that is still existing.
