‘d3dx927.dll’ file is missing.’ – Direct X error
Every time I am installing any software a Direct X error is coming. The error message is ‘The installation of this application is not able to resume because of the Direct X 9 is not available in the computer. The software is not able to open because of the ‘d3dx927.dll’ file is missing. ’ Please help me to fix this problem. I will be thankful for all help and support.
Answered By 10 points N/A #90326
Hi Ynna,
This problem usually occur in error at your Microsoft DirectX. First is to restart your computer, the error may be a one time problem and possible a simple restart could clear it up completely. If it still occurs you need to install the latest version of you DirectX. Google is you friend. If after the installation of Direct x and you still have the error, try to uninstall the software you installed in your computer which the error occurs. If still not solve the error, you need to update your drivers and most of the times updating your drivers could correct your DirectX error.
Hope it helps.
Best Regards,
A.Wright
Answered By 590495 points N/A #323073
If you keep getting errors related to Microsoft DirectX, try installing the latest Microsoft DirectX runtime for your operating system. See the following list for a possible download:
  • Microsoft DirectX 9.0c End-User Runtime – this Microsoft DirectX update is intended for Microsoft Windows XP and Microsoft Windows Server 2003. This downloads the web installer. If you want the offline installer, download this Microsoft DirectX 9.0c (June 10) on FileHippo.
  • Microsoft DirectX 10 – this version is included in Windows Vista and there is no offline update package for this version. To update, install the latest Service Pack for Windows Vista.
  • Microsoft DirectX 10.1 – this version is included in Windows Vista Service Pack 1 and Windows Server 2008 Service Pack 1.
  • Microsoft DirectX 11 – this update is available for Windows Vista and Windows Server 2008 Service Pack 2 with KB971512 installed. This version is included in Windows 7 and Windows Server 2008 R2.
  • Microsoft DirectX 11.1 – this update is available for Windows 7 and Windows Server 2008 R2 Service Pack 1 with Platform Update for Windows 7 and Windows Server 2008 (KB2670838). This version is included in Windows 8, Windows RT, and Windows Server 2012.
  • Microsoft DirectX 11.2 – this version is included in Windows 8.1, Windows RT 8.1, and Windows Server 2012 R2.
  • Microsoft DirectX 11.3 and Microsoft DirectX 12 – these versions are included in Windows 10 and Windows Server 2016 Technical Preview.
