abby69
Posted on - 12/19/2013
I installed AirServer on my Windows 7 PC. I will use this to share my iPhone's screen on my PC through AirPlay mirroring. However, every time I installed it I am getting an error. I really need this to work. I tried to contact AirServer support but didn't hear anything from them as of now. How can I fix this?
Vertex Shader Compile Error
D3DXCompilerShader failed
HRESULT: 0x8007007E
Compilation Errors:
D3DXCompileShader Failed with Error 0x8007007E
Error 0x8007007E means the file is not found and this pertains to some files that are missing from the Direct HLSL compiler installation. In order to fix this, you will need to install DirectX 9c full version. This doesn't matter even if you have the latest version of DirectX in your computer, what you need to install is the DirectX 9c. When done with downloading, just extract the files on your computer and run the setup file to finish the installation.
Download DirectX 9C
